[GRASS-dev] Adding an expert mode to the parser
Margherita Di Leo
diregola at gmail.com
Tue Sep 27 07:36:15 PDT 2016
On Tue, Sep 27, 2016 at 9:15 AM, Margherita Di Leo <diregola at gmail.com>
wrote:
> Hi,
> On Tue, Sep 27, 2016 at 7:13 AM, Moritz Lennert <
> mlennert at club.worldonline.be> wrote:
>> On 26/09/16 23:50, Vaclav Petras wrote:
>>> On Mon, Sep 26, 2016 at 5:24 PM, Veronica Andreo <veroandreo at gmail.com
>>> <mailto:veroandreo at gmail.com>> wrote:
>>> I'm with MaDi in that if I see a very long list of flags and
>>> parameters in the terminal when using --h, i just go to the
>>> manual... I just use --h in CLI for a quick recalling of
>>> flags/options... A reduced list of most commonly used flags would be
>>> nice, but still keep the possibility to get the advanced
>>> flags/parameters as well, if the user needs more info...
>>> If the --help is just for scanning and the issue is that it simply too
>>> long, hiding some parameters is not the only option we have. For many
>>> (and more in the future hopefully) parameters we have (short) label and
>>> (longer) description. --help prints both (if both are present, that's at
>>> least 2 lines per parameter). Additionally, if the option has predefined
>>> values which have descriptions, there is one line for each of those. So,
>>> the question is would it be helpful (at least as a first step) if --help
>>> would print less information for each parameter but still provided all
>>> parameters?
>> In line with your other mail where you caution about "hiding" useful
>> information, how about not changing the --help output, but rather adding a
>> "--simple-help" or somthing like this which would output a simplified help.
> +1.
For inspiration, looking at gdal: http://www.gdal.org/ogr2ogr.html
$ ogr2ogr --help-general
Generic GDAL/OGR utility command options:
$ ogr2ogr --help
Usage: ogr2ogr [--help-general] [-skipfailures] [-append] [-update]
[-select field_list] [-where restricted_where]
[-progress] [-sql <sql statement>] [-dialect dialect]
[-preserve_fid] [-fid FID]
[-spat xmin ymin xmax ymax] [-geomfield field]
[-a_srs srs_def] [-t_srs srs_def] [-s_srs srs_def]
[-f format_name] [-overwrite] [[-dsco NAME=VALUE] ...]
dst_datasource_name src_datasource_name
[-lco NAME=VALUE] [-nln name] [-nlt type] [-dim
2|3|layer_dim] [layer [layer ...]]
Advanced options :
Note: ogr2ogr --long-usage for full help.
$ ogr2ogr --long-usage
Advanced options :
-f format_name: output file format name, possible values are:
Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160927/a4eab679/attachment.html>
