[GRASS-dev] Adding an expert mode to the parser
Rainer M Krug Rainer at krugs.de
Tue Sep 27 00:54:43 PDT 2016
Moritz Lennert <mlennert at club.worldonline.be> writes:
> On 26/09/16 23:50, Vaclav Petras wrote:
>> On Mon, Sep 26, 2016 at 5:24 PM, Veronica Andreo <veroandreo at gmail.com
>> <mailto:veroandreo at gmail.com>> wrote:
>>     I'm with MaDi in that if I see a very long list of flags and
>>     parameters in the terminal when using --h, i just go to the
>>     manual... I just use --h in CLI for a quick recalling of
>>     flags/options... A reduced list of most commonly used flags would be
>>     nice, but still keep the possibility to get the advanced
>>     flags/parameters as well, if the user needs more info...
>> If the --help is just for scanning and the issue is that it simply too
>> long, hiding some parameters is not the only option we have. For many
>> (and more in the future hopefully) parameters we have (short) label and
>> (longer) description. --help prints both (if both are present, that's at
>> least 2 lines per parameter). Additionally, if the option has predefined
>> values which have descriptions, there is one line for each of those. So,
>> the question is would it be helpful (at least as a first step) if --help
>> would print less information for each parameter but still provided all
>> parameters?
> In line with your other mail where you caution about "hiding" useful
> information, how about not changing the --help output, but rather
> adding a "--simple-help" or somthing like this which would output a
> simplified help. Although:
Everybody is so used to using --help (or -h) that I don't think that an
--simple-help would do any good.
Instead, possibly -hh (as in -vv for more verbose) and mention this in
the first line of the help?
This would open even for -hhh if most advanced options are there.
Concerning --help, this should possibly change to displaying the basic
-h
Rainer
>>     and manual pages then (a tab or section for advanced
>>     flags/parameters)...
>> Considering that we have currently as system of (gui) sections which
>> place the options to individual tabs in GUI, isn't showing the different
>> sections in the manual the right thing to do?
> I would prefer this: show everything, but structure it differently,
> i.e. possibly introduce a new parser keyword (advanced: yes) which
> would put the option into a specific section of the manual. IMHO, this
> should be independent of the GUI sections logic as one might to group
> less advanced and advanced options in the same thematic tab...
>> 	IMHO, a major issue however is the lack of examples for the usage of
>> 	more advanced flags or options (or even the required and more common
>> 	ones). Take the case of several i.* modules, for example... but maybe
>> 	this should go in a separate thread :-)
>> Good point. If you have an explanation and example for a flag, perhaps
>> you can understand it and it is not so advanced at the end.
> I think this is actually a major issue: man pages without description,
> notes and example sections are almost useless IMHO. At the foss4g.be
> last week someone presented a simple use of GRASS GIS (to create this
> map [1] for television) and explained how he actually found the GRASS
> GIS manual system extremely well done and useful, because of the
> explanations and examples...
> Moritz
> [1] http://www.rtbf.be/services/meteo/apere
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160927/a7909025/attachment.sig>
