[GRASS-dev] t.connect and t.rast.what not in GUI
Anna Petrášová
kratochanna at gmail.com
Thu Sep 29 15:12:14 PDT 2016
On Thu, Sep 29, 2016 at 5:47 PM, Blumentrath, Stefan
<Stefan.Blumentrath at nina.no> wrote:
> Thanks Anna,
> I just checked the new modules for 7.2.0 listed here:
> https://trac.osgeo.org/grass/wiki/Release/7.2.0-News
> And found that actually none of them seem to have made it into the GUI...
> v.krige on the other hand is still in the GUI though it has been removed from the code...
> I can try to create a new patch for that if you like...
That would be great. I would omit g.gui.datacatalog, d.frame,
d.legend.vect and maybe some others, I don't think we have to have all
modules accessible from menu.
Thank you
> Cheers
> Stefan
> -----Original Message-----
> From: Anna Petrášová [mailto:kratochanna at gmail.com]
> Sent: 29. september 2016 15:20
> To: Blumentrath, Stefan <Stefan.Blumentrath at nina.no>
> Cc: GRASS developers list (grass-dev at lists.osgeo.org) <grass-dev at lists.osgeo.org>
> Subject: Re: [GRASS-dev] t.connect and t.rast.what not in GUI
> On Wed, Sep 28, 2016 at 8:48 AM, Blumentrath, Stefan <Stefan.Blumentrath at nina.no> wrote:
>> Hi,
>> It seems that t.connect and t.rast.what have not been added to the GUI
>> (both in G73 and G72)!
>> Please find attached a patch where I tried to add them. Hope that is
>> the proper way.
>> I placed t.connect under temporal, but it might be better suited under
>> Database, don’t now...
> I added it there and backported to 7.2. Thank you!
> Anna
>> Cheers
>> Stefan
>> grass-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
