[GRASS-dev] t.connect and t.rast.what not in GUI
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Thu Sep 29 14:47:55 PDT 2016
Thanks Anna,
I just checked the new modules for 7.2.0 listed here:
https://trac.osgeo.org/grass/wiki/Release/7.2.0-News
And found that actually none of them seem to have made it into the GUI...
v.krige on the other hand is still in the GUI though it has been removed from the code...
I can try to create a new patch for that if you like...
Cheers
Stefan
-----Original Message-----
From: Anna Petrášová [mailto:kratochanna at gmail.com]
Sent: 29. september 2016 15:20
To: Blumentrath, Stefan <Stefan.Blumentrath at nina.no>
Cc: GRASS developers list (grass-dev at lists.osgeo.org) <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] t.connect and t.rast.what not in GUI
On Wed, Sep 28, 2016 at 8:48 AM, Blumentrath, Stefan <Stefan.Blumentrath at nina.no> wrote:
> Hi,
> It seems that t.connect and t.rast.what have not been added to the GUI
> (both in G73 and G72)!
> Please find attached a patch where I tried to add them. Hope that is
> the proper way.
> I placed t.connect under temporal, but it might be better suited under
> Database, don’t now...
I added it there and backported to 7.2. Thank you!
Anna
> Cheers
> Stefan
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
