[GRASS-dev] [GRASS GIS] #3320: d.text does not show anything with screen position in geographic coordinates or pixels
trac at osgeo.org
Wed Apr 5 19:50:29 PDT 2017
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Display | Version: 7.2.0
Resolution: | Keywords: d.text d.graph
CPU: Unspecified | Platform: Unspecified
Comment (by annakrat):
Replying to [comment:4 hcho]:
> I found the default at=50,50 in DtextController in decorations.py. The
default for d.text is actually the upper-left corner. This option is empty
in GUI, so at=50,50 is totally unexpected. I think it shouldn't have any
hard-coded default. Because of this forced default, we cannot run:
> d.text input=text.txt
> to display text from the upper-left corner.
Positioning in GUI is handled separately, because it needs to be more
interactive. The 50,50 is there to make sure the entire text is rendered
and not cut off anywhere. Flags -p and -g won't work here easily, the GUI
would have to recompute the coordinates. But that should be a separate
ticket I think.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3320#comment:6>
