[GRASS-dev] [GRASS GIS] #3320: d.text does not show anything with screen position in geographic coordinates or pixels
trac at osgeo.org
Wed Apr 5 21:04:46 PDT 2017
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Display | Version: 7.2.0
Resolution: | Keywords: d.text d.graph
CPU: Unspecified | Platform: Unspecified
Comment (by hcho):
Not only in GUI, it happens in d.mon wx0 as well (command line monitor).
Flags -p and -g don't work both in g.gui GUI and d.mon WX monitors. They
only work for direct cairo and png. Would it be difficult to fix -p & -g
in GUI & d.mon WX monitors?
Also, I don't understand why forcing the default position at the center
(50%,50%) would make sure the entire text is rendered without being cut
off. We're losing a lot more space by placing text at the center instead
of starting it from the upper-left corner. We also lost the capability of
starting from the default upper-left corner because now we have to guess
where that would be and type it in the at option. That's not ideal at all.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3320#comment:7>
