[GRASS-dev] [GRASS GIS] #3330: t.rast.to.rast3 error: Argument list too long
GRASS GIS trac at osgeo.org
Fri Apr 7 06:34:15 PDT 2017
 Reporter:  richardc  |      Owner:  grass-dev@…
     Type:  defect    |     Status:  new
 Priority:  major     |  Milestone:  7.2.1
Component:  Temporal  |    Version:  7.2.0
 Keywords:            |        CPU:  x86-64
 Platform:  Linux     |
 The following error is output from t.rast.to.rast3 when more than 5000
 raster layers in a STRDS and used.
 'AFAICT, the issue is not with the number of open files, but with a list
 of map names (arguments) that is too long for the run_command call that
 calls r.to.rast3. A solution to this could be to allow as input to
 r.to.rast3 a file with map names (such as for r.series).
 You should create a bug report for this.
 Moritz'
 Error:
 t.rast.to.rast3 --overwrite --verbose input=capha_test_5 at cahpa
 output=cahpa_test_5_3d
   File "/usr/local/grass-7.2.0/scripts/t.rast.to.rast3",
 line 194, in <module>
     main()
 line 152, in main
     output=output, overwrite=grass.overwrite())
   File
 "/usr/local/grass-7.2.0/etc/python/grass/script/core.py",
 line 408, in run_command
     ps = start_command(*args, **kwargs)
   File
 line 377, in start_command
     return Popen(args, **popts)
   File
 line 74, in __init__
     subprocess.Popen.__init__(self, args, **kwargs)
   File "/usr/lib/python2.7/subprocess.py", line 710, in
 __init__
     errread, errwrite)
   File "/usr/lib/python2.7/subprocess.py", line 1327, in
 _execute_child
     raise child_exception
 OSError: [Errno 7] Argument list too long
 (Fri Apr  7 17:30:33 2017) Command finished (2 sec)
 System Info
 GRASS version: 7.2.0
 GRASS SVN revision: exported
 Build date: 2017-04-07
 Build platform: x86_64-pc-linux-gnu
 GDAL: 1.11.2
 PROJ.4: 4.9.0
 GEOS: 3.4.2
 SQLite: 3.8.2
 Python: 2.7.6
 wxPython: 2.8.12.1
 Platform: Linux-3.13.0-95-generic-x86_64-with-LinuxMint-17.1-rebecca
 More details here: http://osgeo-org.1560.x6.nabble.com/Temporal-framework-
 calculating-annual-5-day-extremes-td5316014.html#a5316295
Ticket URL: <https://trac.osgeo.org/grass/ticket/3330>
