[GRASS-dev] [GRASS GIS] #3332: v.proj - Error in pj_do_transform
trac at osgeo.org
Fri Apr 14 07:35:08 PDT 2017
Reporter: DmitryKolesov | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Default | Version: unspecified
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Sounds like a similar issues as discussed
[https://lists.osgeo.org/pipermail/grass-user/2016-August/074597.html
here].
Could you try creating your second location using the EPSG code instead of
the GeoJSON file and then attempt to reproject ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3332#comment:1>
