[GRASS-dev] GRASS-GIS 6.4.3 Error in GUI startup
Tung Nguyen
tungkttv at gmail.com
Wed Apr 19 13:29:34 PDT 2017
Thank you very much for the reply Luca and Markus!
I know GRASS-GIS 7 is a big improvement from 6 but the program I'm using
only works with 6 :/
Luca was right about the Python version. The system used the anaconda
python version
$ which python
~/anaconda2/bin/python
whereas all the other libraries were originally installed to other version
of python
$ /usr/bin/python --version
Python 2.7.6
I tried to change the default python version back to 2.7.6 following some
guides to no avail (for example here:
https://linuxconfig.org/how-to-change-from-default-to-alternative-python-version-on-debian-linux
In the end, removing anaconda completely solved the problem
$ rm -rf ~/anaconda2
Best regards,
Tung
On Tue, Apr 18, 2017 at 1:01 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> On 17 April 2017 at 21:19, Tung Nguyen <tungkttv at gmail.com> wrote:
> > Hello GRASS dev,
> Hi,
> > $ python --version
> > Python 2.7.12 :: Anaconda 4.1.1 (64-bit)
> probably the problem is here, you are not using the system Python
> version (with wxpython installed) but the Anaconda one, so you have to
> install wxPython in the Anaconda environment
> > -- Tung
> ciao
> Luca
> www.lucadelu.org
Thanks!
-- Tung
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170419/8cfcf6f6/attachment.html>
