[GRASS-dev] GRASS-GIS 6.4.3 Error in GUI startup
Luca Delucchi
lucadeluge at gmail.com
Tue Apr 18 01:01:03 PDT 2017
On 17 April 2017 at 21:19, Tung Nguyen <tungkttv at gmail.com> wrote:
> Hello GRASS dev,
> $ python --version
> Python 2.7.12 :: Anaconda 4.1.1 (64-bit)
probably the problem is here, you are not using the system Python
version (with wxpython installed) but the Anaconda one, so you have to
install wxPython in the Anaconda environment
> -- Tung
ciao
Luca
www.lucadelu.org
