[GRASS-dev] GRASS flyer for the new osgeo branding
Stefan Blumentrath Stefan.Blumentrath at nina.no
Tue Aug 1 14:22:39 PDT 2017
Hi again,
Please find attached two documents where I try to illustrate the suggested changes (with https://github.com/lucadelu/osgeo/blob/ab18927d18bd73bbb58201b2612f608ffbfa8a08/marketing/print/grass_a4.svg as reference).
The TXT is in diff style (removed content starts with a "-" on the line, added content with a "+") and in the ODT I had "track changes" activated.
Hope that helps to identify the proposals for changes.
Cheers
Stefan
-----Original Message-----
From: Luca Delucchi [mailto:lucadeluge at gmail.com]
Sent: mandag 31. juli 2017 10.10
To: Stefan Blumentrath <Stefan.Blumentrath at nina.no>
Cc: Markus Neteler <neteler at osgeo.org>; Anna Kratochvílová <kratochanna at gmail.com>; GRASS developers list <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] GRASS flyer for the new osgeo branding
On 29 July 2017 at 23:51, Stefan Blumentrath <Stefan.Blumentrath at nina.no> wrote:
> Ciao Luca,
Ciao Stefan,
> There is also the R interface (rgrass7) which is not mentioned in the
> “Interfaces” paragraph.
Added
> All this and some other small adjustments can be found in the attached txt.
Sorry but it is to difficult to understand what you changed, please can you send me the proposed changes like others (in a bullet list)
Thanks
> Cheers
> Stefan
ciao
Luca
www.lucadelu.org
Type: application/octet-stream
Desc: GRASS_A4_text.odt
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170801/de5916fe/attachment-0001.obj>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170801/de5916fe/attachment-0001.txt>
