[GRASS-dev] GRASS flyer for the new osgeo branding
Stefan Blumentrath Stefan.Blumentrath at nina.no
Tue Aug 15 05:47:07 PDT 2017
Ciao Luca,
Sorry, did not mean to cause extra work (on the contrary).
I see that I really have to prioritize to get myself at least a dual boot system, as I think the inkscape issues I had were OS dependent (lacking font).
Cheers
Stefan
-----Original Message-----
From: Luca Delucchi [mailto:lucadeluge at gmail.com]
Sent: onsdag 2. august 2017 08.39
To: Stefan Blumentrath <Stefan.Blumentrath at nina.no>
Cc: Markus Neteler <neteler at osgeo.org>; Anna Kratochvílová <kratochanna at gmail.com>; GRASS developers list <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] GRASS flyer for the new osgeo branding
On 1 August 2017 at 23:22, Stefan Blumentrath <Stefan.Blumentrath at nina.no> wrote:
> Hi again,
Hi Stefan,
> Please find attached two documents where I try to illustrate the suggested changes (with https://github.com/lucadelu/osgeo/blob/ab18927d18bd73bbb58201b2612f608ffbfa8a08/marketing/print/grass_a4.svg as reference).
> The TXT is in diff style (removed content starts with a "-" on the line, added content with a "+") and in the ODT I had "track changes" activated.
> Hope that helps to identify the proposals for changes.
Not really (I cannot see the changes in the ODT, the diff is not really a diff :-P, and you used an older version of the svg ) but:
- I will try to merge your proposals
- Some of you proposal are to difficult to accept because they will change to much the structure of the text and I have not time to modify everything
> Cheers
> Stefan
ciao
Luca
www.lucadelu.org
