[GRASS-dev] [GRASS GIS] #2940: Compiling Grass-7.0.3 under FreeBSD: tplot directory (with log)
GRASS GIS trac at osgeo.org
Fri Aug 4 02:52:35 PDT 2017
  Reporter:  pieside  |      Owner:  grass-dev@…
      Type:  defect   |     Status:  new
  Priority:  normal   |  Milestone:  7.2.2
 Component:  Default  |    Version:  7.2.0
Resolution:           |   Keywords:  FreeBSD
       CPU:  x86-64   |   Platform:  Other Unix
Comment (by neteler):
 Replying to [comment:17 lbartoletti]:
 > The most changes to the sources is to replace hardcoded python to the
 specific version used.
 @devs: do we want this upstream?
 https://svnweb.freebsd.org/ports/head/databases/grass7/Makefile?view=markup
 > You can see all changes on
 [https://svnweb.freebsd.org/ports/head/databases/grass7/Makefile?view=markup
 Makefile] and
 [https://svnweb.freebsd.org/ports/head/databases/grass7/files/ patches]
 I see specifically these patches:
 # test writable check change
 https://svnweb.freebsd.org/ports/head/databases/grass7/files/patch-
 include_Make_Install.make?view=markup
 # ctypes GCC flag change:
 lib_python_ctypes_ctypesgencore_parser_preprocessor.py?view=markup
 but I am not sure if to be updated in G7 or not - any dev having a
 suggestion?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2940#comment:18>
