[GRASS-dev] [GRASS GIS] #2940: Compiling Grass-7.0.3 under FreeBSD: tplot directory (with log)
trac at osgeo.org
Wed Aug 9 08:11:04 PDT 2017
Reporter: pieside | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Default | Version: 7.2.0
Resolution: | Keywords: FreeBSD
CPU: x86-64 | Platform: Other Unix
Comment (by mmetz):
Replying to [comment:18 neteler]:
> Replying to [comment:17 lbartoletti]:
> > The most changes to the sources is to replace hardcoded python to the
specific version used.
This can be avoided with `pkg install python` which does not install
python, but creates a link to a specific python version: python -> python2
> @devs: do we want this upstream?
https://svnweb.freebsd.org/ports/head/databases/grass7/Makefile?view=markup
> > You can see all changes on
[https://svnweb.freebsd.org/ports/head/databases/grass7/Makefile?view=markup
Makefile] and
[https://svnweb.freebsd.org/ports/head/databases/grass7/files/ patches]
> I see specifically these patches:
> # test writable check change
> https://svnweb.freebsd.org/ports/head/databases/grass7/files/patch-
include_Make_Install.make?view=markup
This patch removes the writable check. IMHO it is a good idea to have this
check.
> # ctypes GCC flag change:
lib_python_ctypes_ctypesgencore_parser_preprocessor.py?view=markup
Added to trunk and relbr72 in r71356,7 (applied only for FreeBSD).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2940#comment:19>
