[GRASS-dev] Dockerfile now in repo
Markus Neteler
neteler at osgeo.org
Mon Aug 7 15:35:09 PDT 2017
Thanks for the Dockerfile, Vaclav!
On Sun, Jul 30, 2017 at 1:11 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> [Using the thread with the announcement for this answer.]
> It is the Dockerfile. You let Docker build a Docker image using that file
> (Docker looks to the directory specified and finds the Dockerfile, kind of
> like make and Makefile). You then use Docker to run a process in the
> container derived from that image. GRASS GIS is build as part of building of
> the image. See the readme file for examples:
> https://trac.osgeo.org/grass/browser/grass/trunk/README#L53
what do you think of the suggested changes?
https://lists.osgeo.org/pipermail/grass-dev/2017-July/085633.html
I attach the modified Dockerfile which I tested on Fedora (still
creating the Ubuntu docker image). Appears to work fine.
Markus
Index: Dockerfile
--- Dockerfile (revision 71331)
+++ Dockerfile (working copy)
@@ -30,10 +30,8 @@
libpng-dev \
libpq-dev \
libproj-dev \
- libreadline-dev \
libsqlite3-dev \
libtiff-dev \
- libxmu-dev \
make \
netcdf-bin \
proj-bin \
@@ -60,9 +58,7 @@
--enable-largefile=yes \
--with-nls \
--with-cxx \
- --with-readline \
--with-bzlib \
- --with-pthread \
--with-proj-share=/usr/share/proj \
--with-geos=/usr/bin/geos-config \
--with-cairo \
