[GRASS-dev] g.gui.animation freezes when loading strds
Markus Metz markus.metz.giswork at gmail.com
Thu Aug 10 11:34:11 PDT 2017
On Thu, Aug 10, 2017 at 8:15 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Thu, Aug 10, 2017 at 11:16 AM, Pietro <peter.zamb at gmail.com> wrote:
> > Hi Veronica,
> > On Tue, Aug 8, 2017 at 3:46 PM, Veronica Andreo <veroandreo at gmail.com>
> > wrote:
> >> I've also experienced the freezing issue (dunno if it the same thing or
> >> not). Here, the rendering freezes if strds has more than 500 maps. I
do not
> >> even get to the export part. Cancel does not close it, so I have to
kill it
> >> (trunk r71319).
> > Same problem here, when I reach 502 maps raise the following exception:
> > Traceback (most recent call last):
> >   File "/usr/lib/python2.7/site-packages/wx-3.0-gtk2/wx/_core.py", line
> > 16762, in <lambda>
> >   File
"/home/pietro/.local/grass-7.3.svn/gui/wxpython/animation/frame.py",
> > line 194, in SetAnimations
> >   File
"/home/pietro/.local/grass-7.3.svn/gui/wxpython/animation/controller.py",
> > line 305, in SetAnimations
> >   File
> > line 328, in _setAnimations
> >   File
> > line 407, in _updateBitmapData
> >   File
> > "/home/pietro/.local/grass-7.3.svn/gui/wxpython/animation/provider.py",
line
> > 234, in Load
> >   File
line
> > 366, in Render
> >   File "/usr/lib64/python2.7/multiprocessing/__init__.py", line 218, in
> > Queue
> >   File "/usr/lib64/python2.7/multiprocessing/queues.py", line 63, in
> > __init__
> >   File "/usr/lib64/python2.7/multiprocessing/synchronize.py", line 147,
in
> > __init__
> >   File "/usr/lib64/python2.7/multiprocessing/synchronize.py", line 75,
in
> > __init__
> > OSError: [Errno 24] Too many open files
> > But checking the number of opened file on my system, it seems two order
> > lower than the maximum:
> > $ cat /proc/sys/fs/file-nr
> > 23422   0       1628292
> > $ cat /proc/sys/fs/file-max
the OS limit of the number of open files is given in
but that is irrelevant, what matters is the maximum allowed number of open
files for the current user
> > 1628292
> > I’ve attached also the complete log of the command in DEBUG mode, but I
was
> > not able to understand where the problem could be. I’ve also rebooted
just
> > to be sure that the system was fresh, but again after 502 maps it breaks
> > with the same error.
> I just tested 1100 maps without problem. In case this is relevant:
> ulimit -n
> 1024
ulimit -n reports the maximum allowed number of open files for the current
user, this is the relevant limit
A solution to the error "Too many open files" would be to open the
files/maps one at a time and closing them again, similar to the -z flag of
r.series.
Just an idea,
Markus M
> > Any ideas?
> > Pietro
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170810/ab4562d4/attachment.html>
