[GRASS-dev] g.gui.animation freezes when loading strds
Anna Petrášová kratochanna at gmail.com
Thu Aug 10 12:00:29 PDT 2017
On Thu, Aug 10, 2017 at 2:34 PM, Markus Metz
<markus.metz.giswork at gmail.com> wrote:
> On Thu, Aug 10, 2017 at 8:15 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> On Thu, Aug 10, 2017 at 11:16 AM, Pietro <peter.zamb at gmail.com> wrote:
>> > Hi Veronica,
>> > On Tue, Aug 8, 2017 at 3:46 PM, Veronica Andreo <veroandreo at gmail.com>
>> > wrote:
>> >> I've also experienced the freezing issue (dunno if it the same thing or
>> >> not). Here, the rendering freezes if strds has more than 500 maps. I do
>> >> not
>> >> even get to the export part. Cancel does not close it, so I have to
>> >> kill it
>> >> (trunk r71319).
>> > Same problem here, when I reach 502 maps raise the following exception:
>> > Traceback (most recent call last):
>> >   File "/usr/lib/python2.7/site-packages/wx-3.0-gtk2/wx/_core.py", line
>> > 16762, in <lambda>
>> >   File
>> > "/home/pietro/.local/grass-7.3.svn/gui/wxpython/animation/frame.py",
>> > line 194, in SetAnimations
>> >   File
>> > "/home/pietro/.local/grass-7.3.svn/gui/wxpython/animation/controller.py",
>> > line 305, in SetAnimations
>> >   File
>> > line 328, in _setAnimations
>> >   File
>> > line 407, in _updateBitmapData
>> >   File
>> > "/home/pietro/.local/grass-7.3.svn/gui/wxpython/animation/provider.py",
>> > line
>> > 234, in Load
>> >   File
>> > line
>> > 366, in Render
>> >   File "/usr/lib64/python2.7/multiprocessing/__init__.py", line 218, in
>> > Queue
>> >   File "/usr/lib64/python2.7/multiprocessing/queues.py", line 63, in
>> > __init__
>> >   File "/usr/lib64/python2.7/multiprocessing/synchronize.py", line 147,
>> > in
>> > __init__
>> >   File "/usr/lib64/python2.7/multiprocessing/synchronize.py", line 75,
>> > in
>> > __init__
>> > OSError: [Errno 24] Too many open files
>> > But checking the number of opened file on my system, it seems two order
>> > lower than the maximum:
>> > $ cat /proc/sys/fs/file-nr
>> > 23422   0       1628292
>> > $ cat /proc/sys/fs/file-max
> the OS limit of the number of open files is given in
> but that is irrelevant, what matters is the maximum allowed number of open
> files for the current user
>> > 1628292
>> > I’ve attached also the complete log of the command in DEBUG mode, but I
>> > was
>> > not able to understand where the problem could be. I’ve also rebooted
>> > just
>> > to be sure that the system was fresh, but again after 502 maps it breaks
>> > with the same error.
>> I just tested 1100 maps without problem. In case this is relevant:
>> ulimit -n
>> 1024
> ulimit -n reports the maximum allowed number of open files for the current
> user, this is the relevant limit
good to know, that's why I used 1100, because it's higher than the
limit, but it still worked.
> A solution to the error "Too many open files" would be to open the
> files/maps one at a time and closing them again, similar to the -z flag of
> r.series.
I was trying to figure out why they would be opened at all. Not sure yet.
> Just an idea,
> Markus M
>> > Any ideas?
>> > Pietro
>> > _______________________________________________
>> > grass-dev mailing list
>> > grass-dev at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/grass-dev
