[GRASS-dev] [GRASS GIS] #3396: db.in.ogr fails with .dbf files created with Visual Foxpro
trac at osgeo.org
Fri Aug 11 01:29:04 PDT 2017
Reporter: maitl | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone:
Component: Database | Version: 7.2.1
Resolution: | Keywords:
CPU: Unspecified | Platform: MSWindows 7
Comment (by martinl):
Since DBF driver is obsolete in GRASS 7 and will be probably removed in
GRASS 8 I think that reported issue will not fixed. Could you suggest
changes in manual? Ideally as attached patch. Thanks.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3396#comment:1>
