[GRASS-dev] [GRASS GIS] #3396: db.in.ogr fails with .dbf files created with Visual Foxpro
GRASS GIS trac at osgeo.org
Fri Aug 11 02:20:38 PDT 2017
  Reporter:  maitl        |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  minor        |  Milestone:
 Component:  Database     |    Version:  7.2.1
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  MSWindows 7
Comment (by mlennert):
 Replying to [ticket:3396 maitl]:
 > Import of .dbf table created with Visual Foxpro ends with "ERROR: Input
 DSN <C:\mytable.dbf> not found or not readable" . The problem is probably
 related to the .dbf file header where file structure is described
 (https://msdn.microsoft.com/en-us/library/aa975386(v=vs.71).aspx).
 > When  I converted the problematic table in Visual Foxpro environment to
 Foxpro 2.x format (command COPY TO mytable_fox26x TYPE FOX2X), then
 dbf.in.ogr works.
 I cannot reproduce with GRASS 7.2.1 and GDAL 2.2.1:
 > db.in.ogr table_VFP_import_fail.dbf out=test
 Imported table <test> with 5 rows
 > db.in.ogr table_FOX2x_import_ok.dbf out=test2
 Imported table <test2> with 5 rows
 > db.select table=test
 X|Y|PE|ME_MREG|M1HB|M1KU|M1KS|M1LV|M1LM|M1MA|M1TL|M2|JRK|MID|xNullFlags
 373094|6464908|13|47|0|0|0|0|0|47|0|0|150818|483611848311|
 374195|6462403|11|230|23|12|115|0|0|80|0|0|150818|1345853648111|
 374489|6464662|13|184|0|0|4|0|0|180|0|0|270634|907614648111|
 375069|6463314|13|182|0|0|0|0|0|182|0|0|150818|483611048311|
 375288|6472475|13|103|0|0|0|0|0|103|0|0|270634|1016537148111|
 > db.select table=test2
 I also don't think that this would be an issue with the GRASS GIS dbf
 driver as db.in.ogr uses ogr to read the file. So if there is an issue it
 is probably with your version of GDAL.
 What do
 ogrinfo table_VFP_import_fail.dbf
 and
 ogrinfo table_VFP_import_fail.dbf table_VFP_import_fail
 give you ?
 What version of GDAL do you have installed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3396#comment:2>
