[GRASS-dev] [release planning] GRASS GIS 7.2.2
Martin Landa landa.martin at gmail.com
Fri Aug 11 08:05:13 PDT 2017
2017-08-11 15:59 GMT+02:00 Anna Petrášová <kratochanna at gmail.com>:
> I tested 64bit version on windows 10 and it works for me, but lidar
> tools are missing.
you are right, I have accidentally disabled las support also on 64bit
platform. Unfortunately building server is not accessible since
15:00CET (at least for two days) due to network reconfiguration at
CTU. Should be fixed in trunk (r71392). I will do backport later when
first G73 64bit build will be published (probably on Monday). Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
