[GRASS-dev] [release planning] GRASS GIS 7.2.2
Martin Landa landa.martin at gmail.com
Mon Aug 14 02:54:36 PDT 2017
2017-08-11 17:05 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2017-08-11 15:59 GMT+02:00 Anna Petrášová <kratochanna at gmail.com>:
>> I tested 64bit version on windows 10 and it works for me, but lidar
>> tools are missing.
> you are right, I have accidentally disabled las support also on 64bit
> platform. Unfortunately building server is not accessible since
> 15:00CET (at least for two days) due to network reconfiguration at
> CTU. Should be fixed in trunk (r71392). I will do backport later when
> first G73 64bit build will be published (probably on Monday). Ma
well, it broke [1] 64bit even few days ago it worked [2]. No changes
in buliding envirnment since then. Windows mystery, I am lost, any
idea?
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/bin/r.in.lidar.exe:
error while loading shared libraries: libgrass_raster.7.3.svn.dll:
cannot open shared object file: No such file or directory
Ma
[1] https://wingrass.fsv.cvut.cz/grass73/x86_64/logs/log-r71395-321/package.log
[2] https://wingrass.fsv.cvut.cz/grass73/x86_64/logs/log-r71337-316/package.log
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
