[GRASS-dev] [GRASS GIS] #3392: t.register: encoding error
trac at osgeo.org
Fri Aug 11 09:26:04 PDT 2017
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Temporal | Version: svn-trunk
Resolution: | Keywords: t.register encoding
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:5 zarch]:
> I'm not able to reproduce these errors in: `t.create`, `t.register`,
`t.unregister`, `t.remove`.
Ok, here I go again (leaving the stdrs desciption issue aside for the
moment, so t.create is not an issue), with a completely fresh svn checkout
of trunk, applied your two patches, 'temporal_encoding.diff' and
'temporal_script_utils_encoding.diff', compiled.
Get the [http://fatra.cnr.ncsu.edu/temporal-grass-
workshop/NC_spm_temporal_workshop.zip demo location] from the [http
://ncsu-geoforall-lab.github.io/grass-temporal-workshop/ FOSS4G 2014
workshop site]. Use the climate_2000_2012 mapset.
GRASS 7.3.svn (NC_spm_temporal_workshop):~ > g.version -g
version=7.3.svn
date=2017
revision=r71392M
build_date=2017-08-11
build_platform=x86_64-pc-linux-gnu
build_off_t_size=8
GRASS 7.3.svn (NC_spm_temporal_workshop):~ > locale
LANG=fr_BE
LANGUAGE=fr_BE
LC_CTYPE=fr_BE.UTF-8
LC_NUMERIC=C
LC_TIME=fr_BE.UTF-8
LC_COLLATE=fr_BE.UTF-8
LC_MONETARY=fr_BE.UTF-8
LC_MESSAGES=fr_BE.UTF-8
LC_PAPER=fr_BE.UTF-8
LC_NAME=fr_BE.UTF-8
LC_ADDRESS=fr_BE.UTF-8
LC_TELEPHONE=fr_BE.UTF-8
LC_MEASUREMENT=fr_BE.UTF-8
LC_IDENTIFICATION=fr_BE.UTF-8
LC_ALL=
Then follow the steps described there (with light modifications for ease):
t.create output=tempmean type=strds temporaltype=absolute title="Average
temperature" description="Monthly temperature average in NC [deg C]"
g.list type=raster pattern="*tempmean" > rasters_tempmean.list
t.register -i input=tempmean type=raster start=2000-01-01 increment="1
months" file=rasters_tempmean.list
Collecte des informations sur la carte ...
100%
Enregistrement des cartes dans la base temporelle ...
Enregistrement des cartes dans le jeu de données temporel ...
Mise à jour du jeu de données temporel ...
ERREUR :ascii,Mettre à jour les métadonnées, l'emprise spatiale et
temporelle de toutes les cartes enregistrées de <,7,8,ordinal not
in range(128)
t.list and t.list raster seem to show that everything is alright, but IIUC
the output of t.info and t.topology seems to indicate that something went
wrong:
t.info tempmean at climate_2000_2012
+-------------------- Space Time Raster Dataset
+-------------------- Basic information
| Id: ........................ tempmean at climate_2000_2012
| Mapset: .................... climate_2000_2012
| Creator: ................... mlennert
| Temporal type: ............. absolute
| Creation time: ............. 2017-08-11 18:12:14.819514
| Modification time:.......... 2017-08-11 18:12:14.819546
| Semantic type:.............. mean
+-------------------- Absolute time
| Start time:................. None
| End time:................... None
| Granularity:................ None
| Temporal type of maps:...... None
+-------------------- Spatial extent
| North:...................... None
| South:...................... None
| East:.. .................... None
| West:....................... None
| Top:........................ None
| Bottom:..................... None
+-------------------- Metadata information
| Raster register table:......
raster_map_register_031cdb28ede04a64b03d115101b86c0b
| North-South resolution min:. None
| North-South resolution max:. None
| East-west resolution min:... None
| East-west resolution max:... None
| Minimum value min:.......... None
| Minimum value max:.......... None
| Maximum value min:.......... None
| Maximum value max:.......... None
| Aggregation type:........... None
| Number of registered maps:.. None
| Title:
| Average temperature
| Description:
| Command history:
| # 2017-08-11 18:12:14
| t.create output="tempmean" type="strds"
| temporaltype="absolute" title="Average temperature"
t.topology tempmean at climate_2000_2012
+-------------------- Temporal topology
| Is subset of dataset: ...... False
| Temporal topology is: ...... invalid
| Number of intervals: ....... 156
| Invalid time stamps: ....... 0
| Number of points: .......... 0
| Number of gaps: ............ 0
| Granularity: ............... 1 month
+-------------------- Topological relations
| Overlaps: .................. 0
| Overlapped: ................ 0
| Finishes: .................. 0
| Started: ................... 0
| Follows: ................... 155
| Contains: .................. 0
| Equal:...................... 0
| Finished: .................. 0
| Precedes: .................. 155
| Starts: .................... 0
| During: .................... 0
t.remove -f tempmean at climate_2000_2012
Note: registered maps themselves have not been removed, only the strds
File "/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
gnu/scripts/t.remove", line 171, in <module>
tgis.profile_function(main)
gnu/etc/python/grass/temporal/core.py", line 85, in profile_function
func()
gnu/scripts/t.remove", line 157, in main
statement += sp.delete(dbif=dbif, execute=False)
gnu/etc/python/grass/temporal/abstract_space_time_dataset.py", line 1959,
in delete
self.get_id()))
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 23:
ordinal not in range(128)
t.unregister file=rasters_tempmean.list
Unregister maps
100%
Unregister maps from the temporal database
gnu/scripts/t.unregister", line 183, in <module>
func()
gnu/scripts/t.unregister", line 169, in main
sp.update_from_registered_maps(dbif)
gnu/etc/python/grass/temporal/abstract_space_time_dataset.py", line 2295,
in update_from_registered_maps
" all registered maps of <%s>") % (self.get_id()))
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 7:
So, I still have exactly the same issues. My guess is that most of them
come from the fact that the message strings are flagged as translatable
and that in the French translation there are accents... The t.register one
I find more difficult to understand.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3392#comment:7>
