[GRASS-dev] [GRASS GIS] #3392: t.register: encoding error
trac at osgeo.org
Fri Aug 11 09:26:49 PDT 2017
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Temporal | Version: svn-trunk
Resolution: | Keywords: t.register encoding
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:6 huhabla]:
> Moritz,
> can you please provide more information about the errors? Some of them
occurred by calling self.get_id(). The ascii conversion of ids that are
build using "name at mapset" produces an error. Does the map or the mapset
contain special characters?
No, as I said, I use a demo data set. I'm pretty sure it's an issue with
the handling of message translations.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3392#comment:8>
