[GRASS-dev] Inclusion of additional files with add-on
Steven Pawley
dr.stevenpawley at gmail.com
Sat Aug 12 07:45:11 PDT 2017
Hello,
I'm getting around to completing my TODO list for the add-on
r.terrain.texture, which includes generating the additional terrain metrics
(terrain surface concavity and convexity), and calculating the nested 8,12
or 16 class terrain classification as per Iwahashi and Pike (2007).
Everything is working but the script uses r.mfilter, which I supply a
matrix filter to, stored as a text file.
Is there a makefile command that can be used to bundle a text file with the
add on, which can then be found using set_path?
Steve
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170812/d978c465/attachment.html>
