[GRASS-dev] Inclusion of additional files with add-on
Moritz Lennert
mlennert at club.worldonline.be
Sat Aug 12 08:00:50 PDT 2017
On 12/08/17 16:45, Steven Pawley wrote:
> Hello,
> I'm getting around to completing my TODO list for the add-on
> r.terrain.texture, which includes generating the additional terrain
> metrics (terrain surface concavity and convexity), and calculating the
> nested 8,12 or 16 class terrain classification as per Iwahashi and Pike
> (2007). Everything is working but the script uses r.mfilter, which I
> supply a matrix filter to, stored as a text file.
> Is there a makefile command that can be used to bundle a text file with
> the add on, which can then be found using set_path?
Can't you include the filter as a string directly in the code ?
Moritz
