[GRASS-dev] [GRASS GIS] #3407: v.in.ogr fails to import ESRI Shapefile with empty attribute table cells
trac at osgeo.org
Wed Aug 23 10:42:02 PDT 2017
Reporter: mikatt | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.2.1
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by rouault):
I'm just speaking about the OGR side of things. With GDAL 2.2, you have 3
potential states for a field:
- unset -> OGR_F_IsFieldSet() == FALSE. OGR_F_GetFieldAsString() will
return an empty string (it is not allowed to return NULL)
- set, but NULL -> OGR_F_IsFieldSet() == TRUE and OGR_F_IsFieldNull() ==
TRUE. OGR_F_GetFieldAsString() will also eturn an empty string
- set, and not NULL --> OGR_F_IsFieldSet() == TRUE and OGR_F_IsFieldNull()
== FALSE. An empty string is considered as a not-null set field, so a
potential return of OGR_F_GetFieldAsString()
Depending on drivers, they will decide whether to dispatch a field as
unset, set or set with empty string.
The shapefile driver as of GDAL 2.2 will set all fields, either to NULL,
or to a not-NULL set value. Note: for strings, there's no way in .dbf to
distinguish NULL from empty string, so an empty string is mapped to a NULL
field (in previous GDAL versions, this was mapped to a unset field)
The CSV driver has traditionnally mapped an empty field as a an empty
string, and this hasn't changed in GDAL 2.2
Hope that clarifies things. Ah nullness and emptyness....
So perhaps given GRASS constraints and concepts, testing the return of
OGR_F_GetFieldAsString() against the empty string is good enough if you
don't need to distinguish between the 3 above states.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3407#comment:4>
