[GRASS-dev] [GRASS GIS] #3407: v.in.ogr fails to import ESRI Shapefile with empty attribute table cells
trac at osgeo.org
Wed Aug 23 11:33:56 PDT 2017
Reporter: mikatt | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.2.1
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by mmetz):
Replying to [comment:4 rouault]:
> I'm just speaking about the OGR side of things. With GDAL 2.2, you have
3 potential states for a field:
> - unset -> OGR_F_IsFieldSet() == FALSE. OGR_F_GetFieldAsString() will
return an empty string (it is not allowed to return NULL)
> - set, but NULL -> OGR_F_IsFieldSet() == TRUE and OGR_F_IsFieldNull() ==
TRUE. OGR_F_GetFieldAsString() will also eturn an empty string
> - set, and not NULL --> OGR_F_IsFieldSet() == TRUE and
OGR_F_IsFieldNull() == FALSE. An empty string is considered as a not-null
set field, so a potential return of OGR_F_GetFieldAsString()
> Depending on drivers, they will decide whether to dispatch a field as
unset, set or set with empty string.
> The shapefile driver as of GDAL 2.2 will set all fields, either to NULL,
or to a not-NULL set value. Note: for strings, there's no way in .dbf to
distinguish NULL from empty string, so an empty string is mapped to a NULL
field (in previous GDAL versions, this was mapped to a unset field)
> The CSV driver has traditionnally mapped an empty field as a an empty
string, and this hasn't changed in GDAL 2.2
> Hope that clarifies things. Ah nullness and emptyness....
> So perhaps given GRASS constraints and concepts,
Constraints and concepts of dbf/sqlite/postgresql/mysql, to be precise.
As you explained, the OGR dbf driver, which is also used internally in
GRASS for dbf databases, does not distinguish between unset and NULL, thus
import with dbf as GRASS database should work as before.
Regarding import into GRASS, there was no need to distinguish between the
3 possible states, at least there are no known problems.
> testing the return of OGR_F_GetFieldAsString() against the empty string
is good enough if you don't need to distinguish between the 3 above
states.
Regarding export from GRASS to OGR, what happens if a field is not
explicitly set or unset? Is it now unset or set, but NULL? Do we need to
adjust v.out.ogr using `OGR_F_SetFieldNull()` and/or `OGR_F_UnsetField()`
instead of not touching the field at all?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3407#comment:5>
