[GRASS-dev] v.in.osm working?
Even Rouault
even.rouault at spatialys.com
Thu Aug 24 02:15:20 PDT 2017
> You can use v.in.ogr directly for OSM PBF files (
> http://gdal.org/drv_osm.html).
> BTW, with GDAL 2.2.1, using OGR_INTERLEAVED_READING=YES does not
work for
> me (empty vector).
Caution: you cannot just specify OGR_INTERLEAVED_READING=YES and
loop over layers as usual. See the "Interleaved reading" section of http://
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170824/fa50fb30/attachment.html>
