[GRASS-dev] v.in.osm working?
Markus Metz
markus.metz.giswork at gmail.com
Thu Aug 24 06:28:13 PDT 2017
On Thu, Aug 24, 2017 at 10:40 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, Aug 24, 2017 at 9:30 AM, Markus Metz
> <markus.metz.giswork at gmail.com> wrote:
> > On Tue, Aug 22, 2017 at 8:37 PM, Markus Neteler <neteler at osgeo.org>
wrote:
> >> Hi,
> >> does v.in.osm actually work? I am trying to import from a OSM PBF
> >> file, for example:
> >> http://download.geofabrik.de/europe/germany/berlin.html
> >> --> berlin-latest.osm.pbf (51MB)
> >> grass72 ~/grassdata/latlong_wgs84/osm
> > You can use v.in.ogr directly for OSM PBF files
> > (http://gdal.org/drv_osm.html).
> v.in.ogr input=~/Downloads/berlin-latest.osm.pbf type=point,line
output=roads
If you want to convert centroids to points and boundaries to lines, use
type=point,line.
If you want to import only points and lines from the OSM PBF file, use
layer=points,lines (check layer names first with v.in.ogr -l).
Markus M
> Number of nodes: 177060
> Number of primitives: 743673
> Number of points: 550356
> Number of lines: 193317
> Number of boundaries: 0
> Number of centroids: 0
> Number of areas: 0
> Number of isles: 0
> Nice!
> GRASS 7.2.2svn (latlong_wgs84):~ > v.db.connect -p roads
> Vector map <roads> is connected by:
> layer <1/points> table <roads_1> in database
> </home/mneteler/grassdata/latlong_wgs84/osm/sqlite/sqlite.db> through
> driver <sqlite> with key <cat>
> layer <2/lines> table <roads_2> in database
> layer <3/multilinestrings> table <roads_3> in database
> layer <4/multipolygons> table <roads_4> in database
> layer <5/other_relations> table <roads_5> in database
> Problem:
> Only vector queries in the GUI fail with a JSON error. It will be some
> "escape" issue.
> I have opened a ticket for that: https://trac.osgeo.org/grass/ticket/3409
> > BTW, with GDAL 2.2.1, using OGR_INTERLEAVED_READING=YES does not work
for me
> > (empty vector).
> I got here:
> gdal-config --version
> 2.1.3
> v.in.ogr
> Check if OGR layer <points> contains polygons...
> ERROR 1: Too many features have accumulated in lines layer. Use
> OGR_INTERLEAVED_READING=YES mode
> Warning 1: organizePolygons() received an unexpected geometry.
> Either a polygon with interior rings, or a polygon with less than 4
points,
> or a non-Polygon geometry. Return arguments as a collection.
> 100%
> Check if OGR layer <lines> contains polygons...
> 100%
> Check if OGR layer <multilinestrings> contains polygons...
> 100%
> Check if OGR layer <multipolygons> contains polygons...
> 100%
> Check if OGR layer <other_relations> contains polygons...
> 100%
> However, the roads are imported.
> markusN
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170824/3d5a5336/attachment.html>
