[GRASS-dev] GRASS-GIS GUI failed to start
Anna Petrášová kratochanna at gmail.com
Wed Aug 30 12:14:28 PDT 2017
Is this version from packages? There has been some fixes, so maybe if
you could download and compile the latest version:
https://grass.osgeo.org/grass64/source/snapshot/
On Wed, Aug 30, 2017 at 11:23 AM, Tung Nguyen <tungkttv at gmail.com> wrote:
> Hi Vero,
> Thanks for the suggestion! I'd love to however some of the tools we're using
> are only compatible with GRASS-GIS 6.4
> Best regards,
> -- Tung
> On Tue, Aug 29, 2017 at 10:55 PM, Veronica Andreo <veroandreo at gmail.com>
> wrote:
>> Hello Tung,
>> Have you considered moving to GRASS 7.2? The last update of GRASS 6.4
>> series (6.4.4) was released one year ago and won't receive further bug
>> fixing.
>> I would highly recommend to move to grass 7
>> Best,
>> Vero
>> El 30 ago. 2017 12:28 a.m., "Tung Nguyen" <tungkttv at gmail.com> escribió:
>>> Hello GRASS dev,
>>> I'm using GRASS-GIS v6.4.3 on Linux Mint 17.3 Rosa but couldn't get the
>>> GUI to start. I have tried all solutions I could find to no avail. What I
>>> have tried so far:
>>> - Uninstall & reinstall numpy (numpy-1.13.1)
>>> - Uninstall (purge) and reinstall python-wxversion, python-wxgtk2.8 then
>>> grass-core, grass-dev & grass-gui
>>> - Error message:
>>> Welcome to GRASS 6.4.3 (2013)
>>> GRASS homepage:                          http://grass.osgeo.org/
>>> This version running thru:               Bash Shell (/bin/bash)
>>> Help is available with the command:      g.manual -i
>>> See the licence terms with:              g.version -c
>>> If required, restart the GUI with:       g.gui wxpython
>>> When ready to quit enter:                exit
>>> [Raster MASK present]
>>> GRASS 6.4.3 (default):~ > Traceback (most recent call last):
>>>   File "/usr/lib/grass64/etc/wxpython/wxgui.py", line 34, in <module>
>>>     from lmgr.frame import GMFrame
>>>   File "/usr/lib/grass64/etc/wxpython/lmgr/frame.py", line 46, in
>>> <module>
>>>     from lmgr.layertree        import LayerTree, LMIcons
>>>   File "/usr/lib/grass64/etc/wxpython/lmgr/layertree.py", line 37, in
>>> <module>
>>>     from mapdisp.frame       import MapFrame
>>>   File "/usr/lib/grass64/etc/wxpython/mapdisp/frame.py", line 52, in
>>> <module>
>>>     from wxplot.profile     import ProfileFrame
>>>   File "/usr/lib/grass64/etc/wxpython/wxplot/profile.py", line 23, in
>>> <module>
>>>     import wx.lib.plot as plot
>>>   File
>>> "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/lib/plot.py", line
>>> 132, in <module>
>>>     raise ImportError, "Numeric,numarray or NumPy not found. \n" + msg
>>> ImportError: Numeric,numarray or NumPy not found.
>>>             This module requires the Numeric/numarray or NumPy module,
>>>             which could not be imported.  It probably is not installed
>>>             (it's not part of the standard Python distribution). See the
>>>             Numeric Python site (http://numpy.scipy.org) for information
>>> on
>>>             downloading source or binaries.
>>> - Machine info:
>>> $ python --version
>>> Python 2.7.6
>>> $ inxi -Fxz
>>> System:    Kernel: 4.4.0-28-generic x86_64 (64 bit gcc: 4.8.4)
>>>            Desktop: Cinnamon 2.8.8 (Gtk 3.10.8) Distro: Linux Mint 17.3
>>> Rosa
>>> Graphics:  Card: NVIDIA GM107GL [Quadro K620] bus-ID: 01:00.0
>>>            Display Server: X.Org 1.17.1 driver: nvidia Resolution:
>>> 1920x1080 at 60.0hz, 1920x1080 at 60.0hz
>>>            GLX Renderer: Quadro K620/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA
>>> 375.39 Direct Rendering: Yes
>>> Any suggestion would be appreciated. Thanks!
>>> -- Tung
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
> Thanks!
> -- Tung
