[GRASS-dev] GRASS-GIS GUI failed to start
Tung Nguyen
tungkttv at gmail.com
Wed Aug 30 08:23:17 PDT 2017
Hi Vero,
Thanks for the suggestion! I'd love to however some of the tools we're
using are only compatible with GRASS-GIS 6.4
Best regards,
-- Tung
On Tue, Aug 29, 2017 at 10:55 PM, Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hello Tung,
> Have you considered moving to GRASS 7.2? The last update of GRASS 6.4
> series (6.4.4) was released one year ago and won't receive further bug
> fixing.
> I would highly recommend to move to grass 7
> Best,
> Vero
> El 30 ago. 2017 12:28 a.m., "Tung Nguyen" <tungkttv at gmail.com> escribió:
>> Hello GRASS dev,
>> I'm using GRASS-GIS v6.4.3 on Linux Mint 17.3 Rosa but couldn't get the
>> GUI to start. I have tried all solutions I could find to no avail. What I
>> have tried so far:
>> - Uninstall & reinstall numpy (numpy-1.13.1)
>> - Uninstall (purge) and reinstall python-wxversion, python-wxgtk2.8 then
>> grass-core, grass-dev & grass-gui
>> *- Error message:*
>> *Welcome to GRASS 6.4.3 (2013) *
>> *GRASS homepage: http://grass.osgeo.org/
>> <http://grass.osgeo.org/>*
>> *This version running thru: Bash Shell (/bin/bash)*
>> *Help is available with the command: g.manual -i*
>> *See the licence terms with: g.version -c*
>> *If required, restart the GUI with: g.gui wxpython*
>> *When ready to quit enter: exit*
>> *[Raster MASK present]*
>> *GRASS 6.4.3 (default):~ > Traceback (most recent call last):*
>> * File "/usr/lib/grass64/etc/wxpython/wxgui.py", line 34, in <module>*
>> * from lmgr.frame import GMFrame*
>> * File "/usr/lib/grass64/etc/wxpython/lmgr/frame.py", line 46, in
>> <module>*
>> * from lmgr.layertree import LayerTree, LMIcons*
>> * File "/usr/lib/grass64/etc/wxpython/lmgr/layertree.py", line 37, in
>> <module>*
>> * from mapdisp.frame import MapFrame*
>> * File "/usr/lib/grass64/etc/wxpython/mapdisp/frame.py", line 52, in
>> <module>*
>> * from wxplot.profile import ProfileFrame*
>> * File "/usr/lib/grass64/etc/wxpython/wxplot/profile.py", line 23, in
>> <module>*
>> * import wx.lib.plot as plot*
>> * File
>> "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/lib/plot.py", line
>> 132, in <module>*
>> * raise ImportError, "Numeric,numarray or NumPy not found. \n" + msg*
>> *ImportError: Numeric,numarray or NumPy not found. *
>> * This module requires the Numeric/numarray or NumPy module,*
>> * which could not be imported. It probably is not installed*
>> * (it's not part of the standard Python distribution). See the*
>> * Numeric Python site (http://numpy.scipy.org
>> <http://numpy.scipy.org>) for information on*
>> * downloading source or binaries.*
>> *- Machine info:*
>> *$ python --version*
>> *Python 2.7.6*
>> *$ inxi -Fxz*
>> *System: Kernel: 4.4.0-28-generic x86_64 (64 bit gcc: 4.8.4)*
>> * Desktop: Cinnamon 2.8.8 (Gtk 3.10.8) Distro: Linux Mint 17.3
>> Rosa*
>> *Graphics: Card: NVIDIA GM107GL [Quadro K620] bus-ID: 01:00.0*
>> * Display Server: X.Org 1.17.1 driver: nvidia Resolution:
>> 1920x1080 at 60.0hz, 1920x1080 at 60.0hz*
>> * GLX Renderer: Quadro K620/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA
>> 375.39 Direct Rendering: Yes*
>> Any suggestion would be appreciated. Thanks!
>> -- Tung
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
Thanks!
-- Tung
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170830/7505ddc3/attachment.html>
