[GRASS-dev] GRASS-GIS GUI failed to start
Veronica Andreo veroandreo at gmail.com
Tue Aug 29 22:55:08 PDT 2017
Hello Tung,
Have you considered moving to GRASS 7.2? The last update of GRASS 6.4
series (6.4.4) was released one year ago and won't receive further bug
fixing.
I would highly recommend to move to grass 7
Best,
Vero
El 30 ago. 2017 12:28 a.m., "Tung Nguyen" <tungkttv at gmail.com> escribió:
> Hello GRASS dev,
> I'm using GRASS-GIS v6.4.3 on Linux Mint 17.3 Rosa but couldn't get the
> GUI to start. I have tried all solutions I could find to no avail. What I
> have tried so far:
> - Uninstall & reinstall numpy (numpy-1.13.1)
> - Uninstall (purge) and reinstall python-wxversion, python-wxgtk2.8 then
> grass-core, grass-dev & grass-gui
> *- Error message:*
> *Welcome to GRASS 6.4.3 (2013) *
> *GRASS homepage:                          http://grass.osgeo.org/
> <http://grass.osgeo.org/>*
> *This version running thru:               Bash Shell (/bin/bash)*
> *Help is available with the command:      g.manual -i*
> *See the licence terms with:              g.version -c*
> *If required, restart the GUI with:       g.gui wxpython*
> *When ready to quit enter:                exit*
> *[Raster MASK present]*
> *GRASS 6.4.3 (default):~ > Traceback (most recent call last):*
> *  File "/usr/lib/grass64/etc/wxpython/wxgui.py", line 34, in <module>*
> *    from lmgr.frame import GMFrame*
> *  File "/usr/lib/grass64/etc/wxpython/lmgr/frame.py", line 46, in
> <module>*
> *    from lmgr.layertree        import LayerTree, LMIcons*
> *  File "/usr/lib/grass64/etc/wxpython/lmgr/layertree.py", line 37, in
> <module>*
> *    from mapdisp.frame       import MapFrame*
> *  File "/usr/lib/grass64/etc/wxpython/mapdisp/frame.py", line 52, in
> <module>*
> *    from wxplot.profile     import ProfileFrame*
> *  File "/usr/lib/grass64/etc/wxpython/wxplot/profile.py", line 23, in
> <module>*
> *    import wx.lib.plot as plot*
> *  File
> "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/lib/plot.py", line
> 132, in <module>*
> *    raise ImportError, "Numeric,numarray or NumPy not found. \n" + msg*
> *ImportError: Numeric,numarray or NumPy not found. *
> *            This module requires the Numeric/numarray or NumPy module,*
> *            which could not be imported.  It probably is not installed*
> *            (it's not part of the standard Python distribution). See the*
> *            Numeric Python site (http://numpy.scipy.org
> <http://numpy.scipy.org>) for information on*
> *            downloading source or binaries.*
> *- Machine info:*
> *$ python --version*
> *Python 2.7.6*
> *$ inxi -Fxz*
> *System:    Kernel: 4.4.0-28-generic x86_64 (64 bit gcc: 4.8.4)*
> *           Desktop: Cinnamon 2.8.8 (Gtk 3.10.8) Distro: Linux Mint 17.3
> Rosa*
> *Graphics:  Card: NVIDIA GM107GL [Quadro K620] bus-ID: 01:00.0*
> *           Display Server: X.Org 1.17.1 driver: nvidia Resolution:
> 1920x1080 at 60.0hz, 1920x1080 at 60.0hz*
> *           GLX Renderer: Quadro K620/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA
> 375.39 Direct Rendering: Yes*
> Any suggestion would be appreciated. Thanks!
> -- Tung
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170830/a9e57792/attachment-0001.html>
