[GRASS-dev] [GRASS GIS] #3469: i.atcorr: Sentinel-2 support broken on some systems
GRASS GIS trac at osgeo.org
Thu Dec 21 12:26:34 PST 2017
  Reporter:  sbl          |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.4.0
 Component:  Packaging    |    Version:  unspecified
Resolution:               |   Keywords:  i.atcorr
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:6 mmetz]:
 > Replying to [comment:5 mlennert]:
 > > Using
 > > CFLAGS=-g -Wall -Wextra -Wpedantic -Wshadow -Wno-sign-compare -fno-
 common -fexceptions -Werror=implicit-function-declaration
 -Wp,-D_FORTIFY_SOURCE=2 -O3 -fno-fast-math
 > Are you still using
 > CXXFLAGS="-g -Ofast"
 No. I left all ldflags and cxxflags commented, and I don't think -Ofast is
 default.
 > i.atcorr is a C++ module
 Good to know. So do CFLAGS have any impact ?
 > > I again get
 > > r.info -r test_atcorr
 > > min=NULL
 > > max=NULL
 > > So not sure it's the compiler flags...
 > I can confirm on Debian testing, all NULL...
 Good. This means that it is something systematic which we should be able
 to find. Stefan, you tried different versions. Are there any older
 versions which work for you ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:7>
