[GRASS-dev] [GRASS GIS] #3469: i.atcorr: Sentinel-2 support broken on some systems
trac at osgeo.org
Thu Dec 21 13:01:12 PST 2017
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: Packaging | Version: unspecified
Resolution: | Keywords: i.atcorr
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:7 mlennert]:
> [...] This means that it is something systematic which we should be able
to find. Stefan, you tried different versions. Are there any older
versions which work for you ?
It seems that the 6s code in i.atcorr is numerically unstable: some
internal variables can get very close to zero. If these close-to-zero
values are snapped to zero, nan and inf results can appear. This is why
the result can be all NULL, or not.
The symptom can be cured by using double precision floating point
variables throughout. Currently, i.atcorr uses single precision floating
point variables. When using double precision floating point variables,
Debian testing produces reasonable results. However, these results differ
from Fedora 27, also using double precision floating point variables
throughout. I would say that both results (Debian testing and Fedora 27)
are slightly wrong because of the numerical instability of the 6s code in
combination with the sentinel-2 parameters.
I suggest to review the parameters for sentinel-2 as used by i.atcorr.
I also suggest to review i.atcorr. The code has been translated from
Fortran to C++ and might need some manual adjustments.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:8>
