[GRASS-dev] [GRASS GIS] #3469: i.atcorr: Sentinel-2 support broken on some systems
trac at osgeo.org
Thu Dec 21 23:31:29 PST 2017
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: Packaging | Version: unspecified
Resolution: | Keywords: i.atcorr
CPU: Unspecified | Platform: Unspecified
Comment (by sbl):
Replying to [comment:8 mmetz]:
> The symptom can be cured by using double precision floating point
variables throughout. Currently, i.atcorr uses single precision floating
point variables. When using double precision floating point variables,
Debian testing produces reasonable results. However, these results differ
from Fedora 27, also using double precision floating point variables
throughout. I would say that both results (Debian testing and Fedora 27)
are slightly wrong because of the numerical instability of the 6s code in
combination with the sentinel-2 parameters.
Would you be able to provide a patch with those changes? I would not mind
slightly wrong results, just I am able to proceed. I can update the
computation once this is properly fixed...
> I suggest to review the parameters for sentinel-2 as used by i.atcorr.
> I also suggest to review i.atcorr. The code has been translated from
Fortran to C++ and might need some manual adjustments.
I will happily test any fixes on various systems!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:9>
