[GRASS-dev] [GRASS GIS] #3469: i.atcorr: Sentinel-2 support broken on some systems
    trac at osgeo.org
    Fri Dec 22 00:14:25 PST 2017
  Reporter:  sbl          |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.4.0
 Component:  Packaging    |    Version:  unspecified
Resolution:               |   Keywords:  i.atcorr
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:9 sbl]:
 > Replying to [comment:8 mmetz]:
 > > The symptom can be cured by using double precision floating point
 variables throughout. Currently, i.atcorr uses single precision floating
 point variables. When using double precision floating point variables,
 Debian testing produces reasonable results. However, these results differ
 from Fedora 27, also using double precision floating point variables
 throughout. I would say that both results (Debian testing and Fedora 27)
 are slightly wrong because of the numerical instability of the 6s code in
 combination with the sentinel-2 parameters.
 > Would you be able to provide a patch with those changes? I would not
 mind slightly wrong results, just I am able to proceed. I can update the
 computation once this is properly fixed...
 Patch i_atcorr_double.patch attached. i.atcorr is identical in 7.4 and
 7.5, therefore the patch works with both versions.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:10>
