[GRASS-dev] [GRASS GIS] #3469: i.atcorr: Sentinel-2 support broken on some systems
trac at osgeo.org
Fri Dec 22 00:37:35 PST 2017
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: Packaging | Version: unspecified
Resolution: | Keywords: i.atcorr
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:10 mmetz]:
> Replying to [comment:9 sbl]:
> > Replying to [comment:8 mmetz]:
> > > The symptom can be cured by using double precision floating point
variables throughout. Currently, i.atcorr uses single precision floating
point variables. When using double precision floating point variables,
Debian testing produces reasonable results. However, these results differ
from Fedora 27, also using double precision floating point variables
throughout. I would say that both results (Debian testing and Fedora 27)
are slightly wrong because of the numerical instability of the 6s code in
combination with the sentinel-2 parameters.
> > Would you be able to provide a patch with those changes? I would not
mind slightly wrong results, just I am able to proceed. I can update the
computation once this is properly fixed...
> Patch i_atcorr_double.patch attached. i.atcorr is identical in 7.4 and
7.5, therefore the patch works with both versions.
Thanks for investigating this !
I now get what looks like more reasonable results:
r.info -r test_atcorr
min=0.3878489
max=8513.962
compared to the original before correction:
r.info -r B08
min=83
max=7110
Interestingly, i.atcorr also runs much faster with the patch.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:11>
