[GRASS-dev] [GRASS GIS] #3469: i.atcorr: Sentinel-2 support broken on some systems
GRASS GIS trac at osgeo.org
Fri Dec 22 01:51:14 PST 2017
  Reporter:  sbl          |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.4.0
 Component:  Packaging    |    Version:  unspecified
Resolution:               |   Keywords:  i.atcorr
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by sbl):
 Replying to [comment:15 mlennert]:
 > Markus, could it be that you are using the original larger input image
 from the ML and not the smaller clip attached to this ticket ?
 Yes, thanks Moritz! That was it in my case!
 Now:
 r.info -r B08
 min=83
 max=7110
 i.atcorr -r input=B08 elevation=dem range=83,7110 output=test_atcorr
 rescale=0,10000 parameters=p6s.txt --o
 Atmospheric correction...
  100%
 Atmospheric correction complete.
 r.info -r test_atcorr
 min=8.732422e-10
 max=10000
 and
 i.atcorr -r input=B08 elevation=dem output=test_atcorr rescale=0,10000
  100%
 min=3875.138
 max=10000
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:16>
