[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#1898 (master - 7fa0125)
Markus Neteler
neteler at osgeo.org
Mon Feb 6 05:50:47 PST 2017
On Mon, Feb 6, 2017 at 8:49 AM, Rainer M Krug <Rainer at krugs.de> wrote:
> Markus Neteler <neteler at osgeo.org> writes:
>> On Mon, Jan 30, 2017 at 11:20 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>>> Daily build of the Homebrew formula repo seems more appropriate for testing
>>> than the workaround in the code.
>>> Since Travis CI is not 100% reliable for Mac, it will also separate all the
>>> false positives. It still can send messages to grass-dev (all Travis is
>>> already white listed, right?) but more people should get access to the repo
>>> if that's the case.
>> Silly question: why does our Mac script fetch from SVN and not from
>> git? This would solve it.
> It is using the svn repo, as it is the original GRASS repo. Technically,
> there would be no problem at all to use the git repo, but I thought it
> makes more sense to rely on the original authoritative repo.
At time Travis does not accept the SSL certificate of svn.osgeo.org,
that's why the job failed.
> Otherwise, there is no problem at all with using the git repo.
Perhaps yes if that brings back the Mac tests at lowest cost (I know
there is also the homebrew or not thing to decides as well).
Markus
