[GRASS-dev] [GRASS GIS] #3270: v.out.ogr: Append mode broken in G 7.2.1svn and 7.3
GRASS GIS trac at osgeo.org
Wed Feb 8 01:09:38 PST 2017
  Reporter:  sbl          |      Owner:  martinl
      Type:  defect       |     Status:  assigned
  Priority:  normal       |  Milestone:  7.2.1
 Component:  Vector       |    Version:  svn-releasebranch72
Resolution:               |   Keywords:  v.out.ogr
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by martinl):
 Should be solved in r70500. It changes API a bit, the `Flag` structure has
 new attribute - `suppress_overwrite`. For relb72 we have two options:
 a) backport (API change)
 b) revert r70204.
 I would vote for a) since GUI dialog is quite unusable since you need to
 write path to output file by hand. Any opinion?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3270#comment:4>
