[GRASS-dev] [GRASS GIS] #3270: v.out.ogr: Append mode broken in G 7.2.1svn and 7.3
GRASS GIS trac at osgeo.org
Wed Feb 8 01:42:01 PST 2017
  Reporter:  sbl          |      Owner:  martinl
      Type:  defect       |     Status:  assigned
  Priority:  normal       |  Milestone:  7.2.1
 Component:  Vector       |    Version:  svn-releasebranch72
Resolution:               |   Keywords:  v.out.ogr
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:4 martinl]:
 > Should be solved in r70500. It changes API a bit, the `Flag` structure
 has new attribute - `suppress_overwrite`. For relb72 we have two options:
 > a) backport (API change)
 > b) revert r70204.
 > I would vote for a) since GUI dialog is quite unusable since you need to
 write path to output file by hand. Any opinion?
 I wouldn't call it unusable (many of use have used it in that form for
 years), just not very user-friendly.  ;-)
 IIUC, this is not a change of the user-visible API, but of the internal
 API, or ? Then I don't have an issue with that.
 However, (without having looked into this in detail) why can't this "just"
 be directly dealt with within v.out.ogr main.c ?
 Wouldn't something like this do the job ? :
 Index: main.c
 --- main.c      (révision 70501)
 +++ main.c      (copie de travail)
 @@ -488,23 +488,25 @@
      /* check if OGR layer exists */
      overwrite = G_check_overwrite(argc, argv);
      found = FALSE;
 -    for (i = 0; i < OGR_DS_GetLayerCount(Ogr_ds); i++) {
 -       Ogr_layer = OGR_DS_GetLayer(Ogr_ds, i);
 -       Ogr_field = OGR_L_GetLayerDefn(Ogr_layer);
 -       if (G_strcasecmp(OGR_FD_GetName(Ogr_field),
 options.layer->answer))
 -           continue;
 -       found = TRUE;
 -       if (!overwrite && !flags.append->answer) {
 -           G_fatal_error(_("Layer <%s> already exists in OGR data source
 '%s'"),
 -                         options.layer->answer, options.dsn->answer);
 +    if (!flags.append->answer) {
 +       for (i = 0; i < OGR_DS_GetLayerCount(Ogr_ds); i++) {
 +           Ogr_layer = OGR_DS_GetLayer(Ogr_ds, i);
 +           Ogr_field = OGR_L_GetLayerDefn(Ogr_layer);
 +           if (G_strcasecmp(OGR_FD_GetName(Ogr_field),
 +               continue;
 +           found = TRUE;
 +           if (!overwrite) {
 +               G_fatal_error(_("Layer <%s> already exists in OGR data
 source '%s'"),
 +                             options.layer->answer, options.dsn->answer);
 +           else if (overwrite) {
 +               G_warning(_("OGR layer <%s> already exists and will be
 overwritten"),
 +                         options.layer->answer);
 +               OGR_DS_DeleteLayer(Ogr_ds, i);
 +               break;
 -       else if (overwrite) {
 -           G_warning(_("OGR layer <%s> already exists and will be
 overwritten"),
 -                     options.layer->answer);
 -           OGR_DS_DeleteLayer(Ogr_ds, i);
 -           break;
      if (flags.append->answer && !found) {
         G_warning(_("OGR layer <%s> doesn't exists, "
 since we don't need to worry about overwriting at all when we are in
 append mode, or ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3270#comment:5>
