[GRASS-dev] [GRASS GIS] #3270: v.out.ogr: Append mode broken in G 7.2.1svn and 7.3
GRASS GIS trac at osgeo.org
Wed Feb 8 01:50:53 PST 2017
  Reporter:  sbl          |      Owner:  martinl
      Type:  defect       |     Status:  assigned
  Priority:  normal       |  Milestone:  7.2.1
 Component:  Vector       |    Version:  svn-releasebranch72
Resolution:               |   Keywords:  v.out.ogr
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by martinl):
 Replying to [comment:5 mlennert]:
 > IIUC, this is not a change of the user-visible API, but of the internal
 API, or ? Then I don't have an issue with that.
 https://grass.osgeo.org/programming7/structFlag.html
 > Wouldn't something like this do the job ? :
 Probably yes. My intend was to introduce generic solution how to suppress
 overwrite check. Any idea about other modules which could have benefit
 from that? If there is only G72:v.out.ogr we could probably go for local
 modification as you suggests.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3270#comment:6>
