[GRASS-dev] [GRASS GIS] #3270: v.out.ogr: Append mode broken in G 7.2.1svn and 7.3
trac at osgeo.org
Wed Feb 8 02:22:50 PST 2017
Reporter: sbl | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 7.2.1
Component: Vector | Version: svn-releasebranch72
Resolution: | Keywords: v.out.ogr
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:6 martinl]:
> Replying to [comment:5 mlennert]:
> > IIUC, this is not a change of the user-visible API, but of the
internal API, or ? Then I don't have an issue with that.
> https://grass.osgeo.org/programming7/structFlag.html
Yes, this is what I call the internal API. Users are generally not
confronted with this. In my understanding our no-API change rule is about
module API, not internal API, as GRASS GIS is generally not used as a
library.
> > Wouldn't something like this do the job ? :
> Probably yes. My intend was to introduce generic solution how to
suppress overwrite check. Any idea about other modules which could have
benefit from that? If there is only G72:v.out.ogr we could probably go for
local modification as you suggests.
I can't think of another module where one specific choice warrants an
override of overwrite settings...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3270#comment:7>
