[GRASS-dev] Temporal framework: error when trying to register vector maps using register_map_object_list()
Anna Petrášová
kratochanna at gmail.com
Thu Feb 16 18:48:01 PST 2017
On Thu, Feb 16, 2017 at 9:28 PM, Laurent C. <lrntct at gmail.com> wrote:
> Hello all,
> I'm trying to register a list of VectorDataset objects in a STVDS
> using tgis.register.register_map_object_list().
> The same function works fine when trying to register a list of
> RasterDataset objects.
> However, when using it with VectorDataset objects, I get the following error:
> File "/usr/lib/grass72/etc/python/grass/temporal/register.py", line
> 480, in register_map_object_list
> if map_layer.metadata.get_min() is None and \
> AttributeError: 'VectorMetadata' object has no attribute 'get_min'
> Do I do something wrong or should I fill up a Trac issue?
I didn't investigate, but that looks like a bug to me, so yes, please
create a ticket.
Anna
> Thanks for your help,
> Laurent
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
