[GRASS-dev] [GRASS-SVN] r70632 - grass/trunk/scripts/v.report
Martin Landa
landa.martin at gmail.com
Mon Feb 20 00:11:22 PST 2017
2017-02-20 8:58 GMT+01:00 Huidae Cho <grass4u at gmail.com>:
> no problem, I'll backport it.
ok, thanks for taking care about it. Note that only bugfixes or
cosmetics issues (we are close to freeze period) should be backported
to relb72. After releasing 7.2.1 also non-bug (minor new
functionality) issues can be backported. It's good to note such
waiting backports on wiki [1]. Ma
[1] https://trac.osgeo.org/grass/wiki/Grass7Planning#a7.2.2tobebackported
>> > if cols[catcol] == '-1' or cols[catcol] == '0':
>> > continue
>> > @@ -115,7 +116,6 @@
>> > if len(records1) == 0:
>> > try:
>> > - f = grass.vector_db(map=mapname)[int(layer)]
>> > grass.fatal(_("There is a table connected to input
>> > vector map '%s', but "
>> > "there are no categories present in the
>> > key column '%s'. Consider using "
>> > "v.to.db to correct this.") % (mapname,
>> > f['key']))
>> > @@ -142,6 +142,7 @@
>> > for r2 in records2:
>> > records3.append(filter(lambda r1: r1[catcol] == r2[0],
>> > records1)[0] + r2[1:])
>> > else:
>> > + catcol = 0
>> > records1 = []
>> > p = grass.pipe_command('v.category', inp=mapname, layer=layer,
>> > option='print')
>> > for line in p.stdout:
>> > @@ -172,15 +173,18 @@
>> > numcols = len(colnames) + len(extracolnames)
>> > # calculate percents if requested
>> > - if units != '' and units in ['p', 'percent']:
>> > - # calculate total area value
>> > - areatot = 0
>> > + if units == 'percent' and option != 'coor':
>> > + # calculate total value
>> > + total = 0
>> > for r in records3:
>> > - areatot += float(r[-1])
>> > + total += float(r[-1])
>> > - # calculate area percentages
>> > - records4 = [float(r[-1]) * 100 / areatot for r in records3]
>> > - records3 = [r1 + [r4] for r1, r4 in zip(records1, records4)]
>> > + # calculate percentages
>> > + records4 = [float(r[-1]) * 100 / total for r in records3]
>> > + if type(records1[0]) == int:
>> > + records3 = [[r1] + [r4] for r1, r4 in zip(records1,
>> > records4)]
>> > + else:
>> > + records3 = [r1 + [r4] for r1, r4 in zip(records1,
>> > records4)]
>> > # sort results
>> > if options['sort']:
>> > _______________________________________________
>> > grass-commit mailing list
>> > grass-commit at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/grass-commit
>> Martin Landa
>> http://geo.fsv.cvut.cz/gwiki/Landa
>> http://gismentors.cz/mentors/landa
Martin Landa
