[GRASS-dev] [GRASS-SVN] r70632 - grass/trunk/scripts/v.report
Huidae Cho
grass4u at gmail.com
Mon Feb 20 00:19:48 PST 2017
sure. usually, I don't backport, but I'll check the wiki. Thanks.
On Mon, Feb 20, 2017 at 3:11 AM, Martin Landa <landa.martin at gmail.com>
wrote:
> Hi,
> 2017-02-20 8:58 GMT+01:00 Huidae Cho <grass4u at gmail.com>:
> > no problem, I'll backport it.
> ok, thanks for taking care about it. Note that only bugfixes or
> cosmetics issues (we are close to freeze period) should be backported
> to relb72. After releasing 7.2.1 also non-bug (minor new
> functionality) issues can be backported. It's good to note such
> waiting backports on wiki [1]. Ma
> [1] https://trac.osgeo.org/grass/wiki/Grass7Planning#a7.2.2tobebackported
> >> > if cols[catcol] == '-1' or cols[catcol] == '0':
> >> > continue
> >> > @@ -115,7 +116,6 @@
> >> > if len(records1) == 0:
> >> > try:
> >> > - f = grass.vector_db(map=mapname)[int(layer)]
> >> > grass.fatal(_("There is a table connected to input
> >> > vector map '%s', but "
> >> > "there are no categories present in the
> >> > key column '%s'. Consider using "
> >> > "v.to.db to correct this.") % (mapname,
> >> > f['key']))
> >> > @@ -142,6 +142,7 @@
> >> > for r2 in records2:
> >> > records3.append(filter(lambda r1: r1[catcol] == r2[0],
> >> > records1)[0] + r2[1:])
> >> > else:
> >> > + catcol = 0
> >> > records1 = []
> >> > p = grass.pipe_command('v.category', inp=mapname,
> layer=layer,
> >> > option='print')
> >> > for line in p.stdout:
> >> > @@ -172,15 +173,18 @@
> >> > numcols = len(colnames) + len(extracolnames)
> >> > # calculate percents if requested
> >> > - if units != '' and units in ['p', 'percent']:
> >> > - # calculate total area value
> >> > - areatot = 0
> >> > + if units == 'percent' and option != 'coor':
> >> > + # calculate total value
> >> > + total = 0
> >> > for r in records3:
> >> > - areatot += float(r[-1])
> >> > + total += float(r[-1])
> >> > - # calculate area percentages
> >> > - records4 = [float(r[-1]) * 100 / areatot for r in records3]
> >> > - records3 = [r1 + [r4] for r1, r4 in zip(records1, records4)]
> >> > + # calculate percentages
> >> > + records4 = [float(r[-1]) * 100 / total for r in records3]
> >> > + if type(records1[0]) == int:
> >> > + records3 = [[r1] + [r4] for r1, r4 in zip(records1,
> >> > records4)]
> >> > + else:
> >> > + records3 = [r1 + [r4] for r1, r4 in zip(records1,
> >> > records4)]
> >> > # sort results
> >> > if options['sort']:
> >> > _______________________________________________
> >> > grass-commit mailing list
> >> > grass-commit at lists.osgeo.org
> >> > https://lists.osgeo.org/mailman/listinfo/grass-commit
> >> Martin Landa
> >> http://geo.fsv.cvut.cz/gwiki/Landa
> >> http://gismentors.cz/mentors/landa
> Martin Landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170220/08ae9ff5/attachment.html>
