[GRASS-dev] [GRASS GIS] #2750: LZ4 when writing raster rows; better than double I/O bound r.mapcalc speed
trac at osgeo.org
Fri Feb 24 13:00:35 PST 2017
Reporter: sprice | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.2.1
Component: Raster | Version: svn-trunk
Resolution: | Keywords: ZLIB LZ4 ZSTD
CPU: OSX/Intel | Platform: MacOSX
Comment (by mmetz):
Replying to [comment:61 neteler]:
> Replying to [comment:60 mmetz]:
> > Notes on NULL file compression could be added to the raster intro.
> Done in r70669 and r70670.
> Proposal: I would suggest to make NULL file compression the default in
trunk.
Suggested tests:
* have a raster map with NULL cells without NULL compression
export GRAS_COMPRESS_NULLS=1
test the result of r.compress
test the result of r.null -z
* have a raster map with NULL cells with NULL compression
unset GRAS_COMPRESS_NULLS
* have two raster maps, one with compressed NULL cells, one with
uncompressed NULL cells
test the result of mapa + mapb
* add your tests here
Ticket URL: <https://trac.osgeo.org/grass/ticket/2750#comment:63>
