[GRASS-dev] i.superpixels.slic ( was: #3142 Implementing SLIC image segmentation)
Markus Metz markus.metz.giswork at gmail.com
Fri Jan 6 00:28:09 PST 2017
On Tue, Dec 27, 2016 at 9:05 PM, Rashad Kanavath <mohammedrashadkm at gmail.com
> wrote:
> I had pushed a updated version of code:
> Done:
> 1. input is a imagery group from i.group (handles all raster in the group)
> 2. removed rgb2lab conversion
> 3. implementation of id output map
> 4. replaced  fmin with MIN and MAX macro
> 5. compactness is a new option to module? (default is 20 from paper)
> Wonderful, thanks!
> TODO:
> 1. add option for SLICO
> 2. use segment library to avoid memory limitation when reading raster data
> Hope this works now. Let me know If I missed something else.
> Code clean-up:
- please use tools/grass_indent.sh
- move variable declarations to the beginning of a code block
- convert C++ style comments to C style comments
- line 155
  int sz = nrows * ncols;
can cause integer overflow. Use off_t (large raster maps can only be
handled with LFS, i.e. off_t being a 64bit integer).
- fix L157: must be
  int **pdata;
  pdata = G_malloc(sizeof(int) * group_ref.nfiles);
- Lines 317,318 are correct, line 320 is wrong
> And...
> Happy New Year to all :-)
> Happy new year to you too!
Markus M
> On Thu, Dec 22, 2016 at 10:12 AM, Markus Neteler <neteler at osgeo.org>
> wrote:
>> On Thu, Dec 22, 2016 at 12:01 AM, Markus Metz
>> <markus.metz.giswork at gmail.com> wrote:
>> > Adding
>> > #undef MIN
>> > #define MIN(a,b) ((a) < (b) ? (a) : (b))
>> > as in other GRASS modules is a nice solution to keep things simple and
>> > portable.
>> ... how about a adding this and similar definitions to gis.h?
>> markusN
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Regards,
>    Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170106/21eceacf/attachment.html>
