[GRASS-dev] i.superpixels.slic ( was: #3142 Implementing SLIC image segmentation)
Rashad Kanavath
mohammedrashadkm at gmail.com
Sun Jan 22 02:00:46 PST 2017
I fixed all the points from last mail.
On Fri, Jan 6, 2017 at 9:28 AM, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Tue, Dec 27, 2016 at 9:05 PM, Rashad Kanavath <
> mohammedrashadkm at gmail.com> wrote:
>> I had pushed a updated version of code:
>> Done:
>> 1. input is a imagery group from i.group (handles all raster in the group)
>> 2. removed rgb2lab conversion
>> 3. implementation of id output map
>> 4. replaced fmin with MIN and MAX macro
>> 5. compactness is a new option to module? (default is 20 from paper)
>> Wonderful, thanks!
>> TODO:
>> 1. add option for SLICO
>> 2. use segment library to avoid memory limitation when reading raster data
>> Hope this works now. Let me know If I missed something else.
>> Code clean-up:
> - please use tools/grass_indent.sh
> - move variable declarations to the beginning of a code block
> - convert C++ style comments to C style comments
> - line 155
> int sz = nrows * ncols;
> can cause integer overflow. Use off_t (large raster maps can only be
> handled with LFS, i.e. off_t being a 64bit integer).
> - fix L157: must be
> int **pdata;
> pdata = G_malloc(sizeof(int) * group_ref.nfiles);
> - Lines 317,318 are correct, line 320 is wrong
>> And...
>> Happy New Year to all :-)
>> Happy new year to you too!
> Markus M
>> On Thu, Dec 22, 2016 at 10:12 AM, Markus Neteler <neteler at osgeo.org>
>> wrote:
>>> On Thu, Dec 22, 2016 at 12:01 AM, Markus Metz
>>> <markus.metz.giswork at gmail.com> wrote:
>>> > Adding
>>> > #undef MIN
>>> > #define MIN(a,b) ((a) < (b) ? (a) : (b))
>>> > as in other GRASS modules is a nice solution to keep things simple and
>>> > portable.
>>> ... how about a adding this and similar definitions to gis.h?
>>> markusN
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> Regards,
>> Rashad
Regards,
Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170122/a546b76e/attachment-0001.html>
