[GRASS-dev] Fwd: [OSGeo] #1816: upgrade Trac to 1.2 release
Markus Neteler
neteler at osgeo.org
Tue Jan 10 07:53:37 PST 2017
Hi devs,
are we really using TracMetrixPlugin? See below...
Or ditch it?
Markus
---------- Forwarded message ----------
Date: Tue, Jan 10, 2017 at 4:36 PM
Subject: Re: [OSGeo] #1816: upgrade Trac to 1.2 release
To:
Reporter: jmckenna | Owner: strk
Type: task | Status: assigned
Priority: normal | Milestone:
Component: Trac | Resolution:
Keywords: trac |
Changes (by strk):
* cc: neteler (added)
Comment:
SectionEdit upgraded so it will work with Trac 1.2, but TracMetrixPlugin
still fails and has no replacement yet, see https://trac-
hacks.org/ticket/13041 - The only instances using the Metrix plugin are
the GRASS and QGIS (deprecated) ones.
Markus: how useful is the Metrix plugin for you guys ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1816#comment:7>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
